WTB N/A 5th gear
Rainman
if you mean the early 5th gear (the .73 ratio) for low cruising revs, i have a complete early transmission with a busted differential that you can have for $50 so you'll have all the parts needed
Thanks V2, that's exactly what I'm doing. Let me get my schedule worked out and I'll send you a PM.
Does it matter what year trans you or I have, or will all N/A 5th gears fit on all Turbo trans's?
Rainman
Shouldn't matter, the early transmissions all came with that tall 5th gear.
Here's a quick layout I found in a search...
'82 - '87 NA ----Turbo
1st - 3.600 ---- 3.500
2nd - 2.125 ---- 2.059
3rd - 1.458 ---- 1.400
4th - 1.071 ---- 1.034
5th - 0.730 ---- 0.829
Final - 3.889 ---- 3.375
And here's a step-by-step guide to the swap.
http://www.porschehybrids.com/gallery/5th-Gear-Swap
