Are my Lindsey Racing Chromoly control arms safe?
I've read several posts on this forum stating that the LR control arms are unsafe as they are using heim-joints in shear rather than in compression and tension. My car came with a brand new set of these arms, and I'm having a lot of trouble making them work with my stock ARB.
Am I wasting my time trying to make a set of unsafe arms work, or should I stick with them? I'm aiming to track my car 3-4 times a year.
I have a freind who built his own control arms and used heim joints and hasn't had an issue that I know of. Been running for many years as a track only car.
Sounds promising, but his heim joints might be much stronger than the ones LR uses. Is anyone here running the LR arms on a track car? If so have you ever seen them fail?
BTW Doc. I notice you are using a scissor lift. Is this something you would recommend someone with limited space?
I really wanted to get a max jax, which is a mid rise 2 post, but it was just wide enough that it would have killed parking in my second stall (I would have left it permanently installed). The scissor lift was a compromise, but after using it, I am extremely happy with it. I was limited by both height and width since I have just a standard 2 car garage.
I'm surprised people aren't responding to this question. I posted a similar question over at Pelican 6 months ago and so far Doc is the only one who has offered an opinion. Does this mean that no one are running these arms or tracking them, or should this thread be in a different forum?
Honestly I think the question is in the right place, just not a lot of folks using the control arms...
I got nothing other than to ask Lindsey about use of the factory ARB with their control arms...
Looking at the pictures of the control arms on the site, and the design looks alright to me. The only heim joint I see is at the lower ball joint and its not mounted differently than expected. As long as its sized appropriately, which I have no idea, I don't see any reason why it'd be unsafe. With any race derived part though I would inspect them regularly.
The reason I worry is that some members of the forum have stated (rightfully) that heim joints should never be used in single shear. They are made to take huge loads in tension and compression, but not in shear. That's why I would want to hear from someone who knows if these particular arms, with these particular heim-joints have held up to road and track use ore not. Some of the back roads i run probably put more stresses on the undercarriage and steering than track use does. Due to frost the surface rises, sinks, cracks and splits causing the car to be tossed about quite a lot. I'm probably not braking as hard as I would on track, but the braking zones are much more bumpy. On the other hand the factory arms break as well from time to time, and who knows what a rebuilt set might have gone through...
I'm awaiting his reply, hopefully he has a solution.
To clarify: I'm having issues with the old and discontinued A-arms which had the drop link bracket welded longitudinally to the top of the front tube. The arms have been redesigned to correct the problem. I see no reason for the new arms to have any problems with the drop links at all as they use the stock mounting locations and method.
Also. If I end up having to get a set of stock arms do I absolutely have to get the M030 ones (1990 japanese Turbo), or can I use any late offset arm with a longer pin?
Today is a happy day.
FYI.
I have spoken to both 944 online and Travis at Rennbay who both said they would have no qualms running the LR control arms, and had never heard or seen that they are failure prone. They offered this advice independently and despite the fact that I was calling for information on their rebuilt arms. Both companies impressed me with their straightforward advice and willingness to help.
I would also like to let anyone reading this post know that Lindsey has come through with a solution which will solve my problems permanently. Great customer support also from him.
FYI.
If I am remembering them correctly, they are the black chromoly tubular arms. They are now known to break. I've seen them break at the welds and fully detach from the car. After an engineer's review, it appeared several aspects of the construction were insufficient.
Only to say that I would recommend replacing them.
I Will Second French Toasts post... 2 years ago at Watkins Glen I seen an Arm Break.. Mainly at the welds. As a former Professional welder I can tell you that there was Not even close to enough filler rod on the weld joint. It looked as if they just melted the two parts together with no additional Rod. FWIW, I don't think Lindsey ever made those arms.. they are High Strung 44 arms..
I have high strung, bought them about a 1 1/2 year ago, they looked pretty good quality for my untrained eyes. I do a visual inspection before every track day and so far no issues. They did improve the handling as my car was lowered and suspension geometry needed to be corrected. Will keep an eye on them and report if I have any issues.
