Anyone have a pic of the grounds under the dash in an early car?
I hit all the ground points except for the ones under the drivers side of the dash. I searched around for a half an hour and could not find them. Maybe on an early car they are located somewhere else. I could only find a ground wiring diagram for late cars. I thought they were supposed to be just behind the fuse block.
I got the one in the trunk (left rear)
The battery ground
The ground from the engine block to the firewall
The two ground points on top of the bell housing
The ones by the headlights.
The ones behind the glovebox.
The one for the fuse block (or near the fuse block) should be the only one I'm missing.
The battery ground
I saved these from a thread on the subject, Search may turn up the whole thread. You must have to drop the fuseboxes down to see these, I could never find them on my '84
That is an an old thread of mine. The above picture is for the post 85.5 cars. The early car is completely different. There are two spade terminal points (i think its 4-5 connections at each corner) in the upper left and upper right corners behind the dashboard of the early cars. Its a major PITA to get at them as they are tucked way up in the corner.
