Sunroof not working...
Hit the button and nothing happens.
Fuses are good.
Next thing to check?
I want to replace this stuff with the manual latches. Anyone have a set for sale and a DIY on it?
Fuses are good.
check out clarks-garage.com. Awesome write up there. Also, check
https://rennlist.com/forums/924-931-...-tutorial.html
Still in the process of dealing with my own non-working sunroof. Let us know what helps and what works.
There are a series of micro switches that control the roof movement. Most are located on the drive system in the rear hatch,but the one that gave me trouble is in the roof above the rearview mirror. Push on it and see if the motor runs. Also,if the motor runs,the plastic gears might be stripped. As stated above ,read Clark's Garage. Good luck.
Fred
Fred
I just finished ripping put the electric parts in my car. If you need a piece let me know I will mail it off. Most of the parts I took off seem ok. Except the microswitch on the windshield. That's broken.
There's a microswitch at the front of the sunroof? The only switches I knew of when I replaced my stripped gears were at the back of the car near the motor. Where exactly is this switch, and what purpose does it serve?
We're talking a 944/51, right?
Right in the center of the sunroof, above the rear view mirror is a plastic cap that the middle black arm makes contact with. There's a microswitch behind this cap. The microswitch stops the sunroof in the fully raised position in earlier 944's but on later 944's is a backup to limit switch 3. When this isn't working it will keep the sunroof from working in the open direction.
I'm no genius on this, as I've stated, since my sunroof is still not working, but that little bugger of microswitch is definitely up there between the two sun visors.
Doc, check the relay. Mine wasn't working, all fuses and limit switches were good, and it ended up being the relay.
It was the front microswitch. Had us chasing our tails for a bit, ended up having everything disassembled before we tested the front microswitch.
