Replace Caster Blocks/Rear Control Arm Bushing or not?
Just finished up inspecting the car for the track season and took some pics of the caster blocks/rear control arm bushings. Lookng for opinions whether I should replace them or not based on their condition. Thanks!
![](https://lh3.googleusercontent.com/_AueOlEJLNq0/TVxpjGaWKcI/AAAAAAAAB-A/4wEpJktd3SA/s800/Caster%20Block%20Right.jpg)
![](https://lh3.googleusercontent.com/_AueOlEJLNq0/TVxpijyQ18I/AAAAAAAAB98/FI36ZG5cITk/s800/Caster%20Block%20Left.jpg)
I guess I was thinking right. It appears not to be that hard replacing them.
However, do I have to disassemble the whole suspension at the front or just remove the three bolts related to the caster block? Is there a way to skip alignment after replacing them?
If heavy tracking might I suggest monoballs, I put them on my 951, and didn't have a single complaint in 10K miles of street use...
