Cheaper E Code lenses
http://cgi.ebay.com/ebaymotors/7-H60...Q5fAccessories
Saw those on ebay and was curious if anyone on here has run them. I was thinking of ordering a set now that I have my foglights addressed. I would like to run a H4 bulb.
With $14 to ship to Canada via USPS, they would be worth a try. That is about the same as 1 Sylvania Silver Star sealed beam up here. Their vendor rating on eBay is very good too. I was going to order the Hella E-Code ones from www.rallylights.com , but given that my 924 is on a budget at this point...
The last cars that I had with round headlights were my 1978 Ford Fiesta, and my 1980 VW Rabbit, over 20 years ago. I had the Bosch H4 headlights in both of those, and I was really happy with them. By contrast, I had the Hella H4 square low-beams in my Audi 4000, and they were WORSE than the stock sealed beams (truly disappointed). I do remember the odd pattern in the Bosch, and the funny hot-spots and lines in the pattern. The Hella look similar, so I could see room for improvement.
The Cibies look amazing, and they should be for the price (unless you find a real bargain on a set). I still would not consider these Autopal units to be a big risk at that price, and at worst they would be better than the sealed beam units in my car now.
I think I shopped and found a pair of Hellas brand new for $75 shipped last year. I put Sylvania Silver Star bulbs in them and I'm quite happy.
I'd spend a little extra and get them.
The hellas are the best "compromise" on the market. Though they do not have quite as sharp of a pattern as the Cibies, they are much more rugged. Just search on here. 7" Cibies crack like crazy and I have never even heard of a 7" Hella ecode failure.
I fully agree with you there. I cracked a few on a '74 Alfa Spider with covered headlights... Got caught out in the rain, and I guess when water dripped between the body and covers on the lenses they cracked then.
There is absolutely no reason everyone shouldn't upgrade to the H4s. Even if you don't plan on running brighter bulbs. Our wiring is getting old, and switches are wearing out, and are expensive to replace. It takes 10min to install the new harness, the new lights are much better quality than the sealed beams, and it will save you the time and torture of finding a short in the stock wiring, which will happen sooner or later.
With the H4 harness, the only load on the stock headlight system is the draw of a pulling the switch on a relay....which is almost non-existent.
Its one of those "required" upgrades for a 944. Like the throttle cam, and a performance chip. Sure the car works without them, but they are so cheap and easy to do, the benefits FAR outweigh the cost/time of doing them.
FWIW, every lens is a compromise and there is no one lens that's the best at everything. Different lenses are better at usually one thing or another, so you have to take in account what specific aspect is the most important to you (i.e., city driving, high beam usage, better lit peripherals, etc). For example, most of my driving is done in the city with a lot of unlit signage. The best EU lens for me is made by WorldPac (but I don't recall the specific model). I've tried two pairs of their lenses, and I can't keep them from cracking - they just don't like being mounted as pop-up headlights. Cibie is the same way - the glass is just too thin around the edges. So I've had to compromise and go with the flat-lens Bosch.
I have been curious about some of the new LED lamp assemblies that are starting to become available. While I'm not quite sold on the technology in this application yet, I'd like to see where they are now.
Classic garage sell cibie e code reproductions at a reasonable cost. I ordered some for 1991 S2 before I realized that I could not use seal beam replacements as I had the headlight level adjusters (RoW option). I had to change because my car came from Japan (still left hand drive) but the headlights were for right hand drive as per Japan. Ended up buying new Porsche parts ($550) so these Cibie clones look like a real bargain.
http://classicgarage.com/7rounheadwit.html
That looks like a very good option. Do you still have the ones that you couldn't use? If you do, and want to sell them, let me know. I 'd rather spend a little to ship across country (Ontario), than give the money to brokerage/shipping from the US.
i did the e- code lense h-4 upgrade with new harness to my s2 and although happy with end result have a quick question: what wattage h-4s are you guys running? my kit came with hella h-4 60/55 watt bulbs . how much higher can i go and is there much difference ? was thinking maybe the kit came with " conservative " bulbs.
