944S2 is eating DME relays :S
Car won't start, so I toss in a new DME relay, room! she fires up and idles no problem. So I shut it off and go to start it the next day it just keeps cranking over and over. I put in another DME relay room! it fires up again. You get the point. Any ideas what could be wrong?
Inspect the relays that you have removed, looking for signs of failure such as burnt or cracked traces.
The relay cover can be removed to to allow for close inspection. Also check the back side of the relay /fuse assembly for loose connectors or wires.
Good luck
Good luck
Does the DME relay get hot to the touch while it is running? If it does, you have a part that is drawing too much current and burning up the contacts in the relay. Go to Clarks garage and put in the bypass jumpers. Then, check the current draw through the jumpers as you take out the Fuel pump, DME, idle controller, injectors.
Check the back side of the panel for a corroded or poor connection that is high resistance. Could also be a fuel pump that is pushing against a plugged filter and drawing high current, or otherwise in death throes.
I'm having this same issue. The fuel pump relay gets pretty warm. Let me know what you find. I'll have to work on mine next week.
So, not to hijack your thread but...is there a way to check if the fuel pump is going out with a multimeter? I looked on clarks garage but couldn't find anything other than how to replace the pump itself. Or is it just one of those things that goes out and there's no real way to tell?
Maybe that is why the DME relay has such a poor reliability track record, it is the weak link under heavy current loads. Another feed (straight from the ignition switch) that could use a fusible link, is to the ignition coil.
