Steering Wheel
Old Feb 6, 2011 | 09:54 AM
OntarioTurbo's Avatar
OntarioTurbo
Default Steering Wheel
My stock Porsche steering wheel needs recovering. Thinking about purchasing a Momo Prototipo instead since it seems to be around the same price as recovering.
Also, I have the spacer behind my wheel. Can I use a nonspacer wheel or is my shaft too long for this?
What kind of wheels are you guys using and/or like?
Old Feb 6, 2011 | 02:47 PM
seafeye's Avatar
seafeye
I have an 1987 wheel you can have for $20 plus shipping. Needs a good cleaning. Non airbag.
Old Feb 6, 2011 | 03:50 PM
odurandina's Avatar
odurandina
Team Owner
From: one thousand, five hundred miles north of Ft. Lauderdale for the summer.
i'm a broken record. Porsche 968 CS wheel. unfortunately they're pricey.
File Type: jpg
File Type: jpg
Old Feb 6, 2011 | 04:59 PM
ahetzel's Avatar
ahetzel
Have had the 968 CS wheel in my turbo for the last two years. Best wheel ever, worth every penny and the time it took me to disconnect the airbags properly.
Old Feb 6, 2011 | 05:43 PM
n_hall's Avatar
n_hall
i like the prototipo and the monte carlo on our cars.
i don't know what you mean by spacer.
but to put a momo on a car you need to get the hub adapter. it puts it right around the stock distance. maybe a fraction of an inch difference, if i remember right.
Old Feb 6, 2011 | 06:56 PM
ahetzel's Avatar
ahetzel
Guess its preference, I have two 944s, one with the 968 CS wheel and a race car with a Momo Monte Carlo. I like the CS wheel better. They both end up slightly further from the dash but not much.
Old Feb 6, 2011 | 07:02 PM
DHC6's Avatar
DHC6
I have the CS as well, and I love it. I have had plenty of others over the years (albeit in other cars) and this one is by far the best one yet. Love it!
Old Feb 6, 2011 | 07:45 PM
Jim 944S's Avatar
Jim 944S
seafeye...
If OntarioTurbo passes on that steering wheel ('87), I'd certainly like to have it!
Thanks!
Jim 1987 944S (zip is 33428)
Old Feb 6, 2011 | 08:12 PM
ernie9468's Avatar
ernie9468
Migth be a little more expensive but if you can go with an SC do it ,did upgrade to one in my 968 last year you simply can compare to a Momo Prototipo or Dino (had one in my 944).They are very easy to DIY & all hardware come with it ,no hassle -no spacer-no hub adapter.They are available from Sunset Porsche (drawback available in black only).LOL once you grip that thing in your hand it's heaven.
Old Feb 6, 2011 | 08:24 PM
odurandina's Avatar
odurandina
Team Owner
Originally Posted by ernie9468
Might be a little more expensive but if you can go with an SC do it... you simply CAN'T compare....
i don't like the idea of going cheap on anything that i have to look at and touch... (not sure that came out right).
a few hundred dollars for a wheel you'll be loving for the next 45 years is nothing.
i have a 996 airbag wheel. the mods i had to do to get this wheel in weren't easy. all worth it.
File Type: jpg
Old Feb 7, 2011 | 05:07 AM
Cyberpunky's Avatar
Cyberpunky
That 968 wheel looks very similar in shape to my momo, which also feels great in the hand. Might have to put the 968 wheel into the *to do* list, but will definately try and test one first. looks great though
Old Feb 7, 2011 | 09:53 PM
OntarioTurbo
Seafeye: is the '87 non airbag wheel the same four spoke wheel that came on the '86's and although it needs cleaning is the leather in good condition with no excess wear areas or rips?
Ernie9468: Where is Suset Porsche located? Any chance of getting a 968 CS wheel for a decent price on ebay?
Old Feb 7, 2011 | 10:59 PM
ahetzel's Avatar
ahetzel
Just bite the bullet and buy a real 968 CS wheels. It is what connects you to your car.
Old Feb 7, 2011 | 11:13 PM
seafeye's Avatar
seafeye
I took it off right when i bought the car and put on a Momo. From what i remember it just needed a good cleaning. The whole car was dirty. Tomorrow i will go out there (Garage) and take a couple of pictures of it. Have a extra boxster wheel as well if that would fit???
Old Feb 7, 2011 | 11:34 PM
odurandina's Avatar
odurandina
Team Owner
the boxster wheel must be reduced. you'll need to bore about 1/8~3/16" out of the front of the wheel and cut about 1/4~5/16" off the rear to reduce the wheel by 7/16" such that it will fit over the shorter 944 or 968 shaft..... then you'll need a 993 or 996 clock spring and make some additional mods.
