Broken timing belt - what is the realistic value?
Old 01-31-2011, 12:18 AM
JohnKoaWood
JohnKoaWood's Avatar
Not to mention 3K for an early 944 with 200K on the clock is being generous... considering I paid 3200 for a running 951 with less mileage...
OP, you COULD fix it, and continue to enjoy it.. or sell it and be prepared to get between $500 and 1K depending on how long you are willing to wait for a buyer...
FWIW, the wheels alone could be sold for more than the entire car! And you will probably get more $$ out of the loose accessories than the car.
Old 01-31-2011, 12:47 AM
kenkawai993
kenkawai993's Avatar
Originally Posted by JohnKoaWood
So.. let me get this straight... fix it for 1500 - 2000 to make 2000 more than it can potentially sell for as is?
correct!
Old 01-31-2011, 08:23 AM
Van
Van's Avatar
Just get a used head - probably a few hundred $$ here on RL. Then have it fixed. That should put the repair under $1k Then you might be able to sell it for $2500. Otherwise, I agree, you're looking at under a grand - probably $500. Parting it out would yield more money.
Old 01-31-2011, 05:07 PM
JerryW
JerryW's Avatar
A non running car in NorCal fetches $500 - $1000 irrespective of parts and mods. If you aren't going to fix the motor put all the stock parts back on and craiglist it. Sell the aftermarket parts seperatly.
Old 01-31-2011, 07:10 PM
rgs944
rgs944's Avatar
If the plan is to sell it I would not put one dime into it. Not worth your time and hassle when you could be enjoying other things. If you like the car fix it and keep it for the long haul. Hopefully 5 years from now the survivors will be worth something again. We all know how rare good cars are, even today. 10 years from now they will be an endagered species.
Old 01-31-2011, 09:55 PM
Excelerate
Excelerate's Avatar
Maybe you could find a good junkyard motor for less and just do a straight swap? I have no idea what an n/a longblock goes for, but if you find a car that's been rear-ended or hit in the side you could try to swap it in and sell for a profit or enjoy driving for a while.
Old 02-01-2011, 12:25 AM
Van
Van's Avatar
It's far less time to do a head swap vs. a whole engine swap...
Old 02-01-2011, 12:39 AM
944Ross
944Ross's Avatar
It sounds like the water pump took out the belt, maybe the tensioners are bad too. 25k into the system's life, you'd want to replace a lot, looking at $400 in parts alone to do a turbo WP, new belt and tensioners, then at best $500 for the head work. That's doing it all yourself, and assumes you already have the tools. If you've got the time to do it, super, otherwise cut your losses.
Around here, mechanics will buy a car like this that needs lots of labor for as good a money as you'd get on the street, and fix it on the side for some extra money. They also get parts for a discount (sometimes).
Old 02-01-2011, 01:11 AM
white924s
white924s's Avatar
Originally Posted by red9four4
I was driving along and lost power, thought it was the fuel pump or relay but it was a broken timing belt. I don't want to fix it as it most likely has a bent valve, water pump was leaking, and clutch needs replacing soon. I do not want to part it out either as I do not have the time or patience.
The only mods are:
MSDS ceramic coated headers (have 2 sets of stock headers and an extra cat)
Short shifter (have stock one in a box)
Corbeau seats (have stock ones would prefer to sell with stock ones and use these somewhere else, stock driver seat has tears on the bottom)
Stereo (will remove subs and amp, door panels are custom cut for components)
17x9 rear 17x7.5 front wheels (rear tires are worn, 2 wheels could be repainted)
Momo steering wheel
aluminum pedals
I also have a never installed fiberwerks front bumper.
I have 3 mahle oil filters. The bumber and oil filters could be sold separably.
Car is located in California and has about 180-200k on the odometer (was broken when I got the car but I fixed it).
What do you think I could get for it as is?
Slightly off topic, but did you have to cut the metal of the doors to fit the component woofers in?
Old 02-01-2011, 05:25 AM
Excelerate
Excelerate's Avatar
That would normally be true if the bent valve was the only problem, but in the original post he said his WP and clutch also need changing - if an engine came fully dressed for a few hundred it might be worth it to slap on fresh belts and swap it in. Of course, such an engine with an unknown history might very well be a ticking timebomb waiting to happen, but I just hate seeing such a beautiful looking car go to scrap or parted out just because of a few mechanical issues.
Old 02-01-2011, 09:11 AM
M758
M758's Avatar
The wheels are worth more than the car.
Sad but true.
Old 02-01-2011, 09:53 AM
Van
Van's Avatar
Ahh, I missed that.
Old 02-01-2011, 10:49 AM
NYCpersian
NYCpersian's Avatar
pm sent...
Quick Reply: Broken timing belt - what is the realistic value?
