Brake bleeding turned into a fiasco!
Well, the brakes went fine but after i bled the clutch slave cylinder it wants to stay to the floor. If I pull on it, it springs back up. I attemped to bleed it again for quite some time and get no fluid. My vacuum pump is working fine and the resioir is at the max level. What GIVES ?
Christian
Christian
