Project Car running rich issue
Engine back together with all new parts and including, O2, Plugs, wires, cap, rotor, ISA, fuel press Reg and damper.
The car starts with a little after a few turns and is a little ruff for just a min or 2. Very rich on startup, but tones down a little after she is warmed up. Runs fine other than the dark cloud.
I have read and read any other clues?
Items not replaced.
Temp Sensor
Remote Temp Sensor
MAFM
Throttle Switch
Items not replaced.
Temp Sensor
Remote Temp Sensor
MAFM
Throttle Switch
FQS switch, Needs to be adjusted. Look it up. Use a Hunter sprinkler key. insert into the DME and turn all the way to the left, That is zero setting. Every turn to the right adjusts the timing and fuel mixture. I have a beast of a car and had to adjust it to a richer setting. When you spool up, you need to be rich in fuel otherwise you will wreck motor.
Hey man - glad to see a post of yours - hadn't heard from you in a while.
These cars are designed to run a little richer for the first couple minutes until they are warmed up - I've seen it myself on the wideband.
