FS: Ford brown top injectors, 36#
Old 12-22-2010, 08:26 PM
Andy1212
Andy1212's Avatar
Default FS: Ford brown top injectors, 36#
Bought these from spence a while back for $50 shipped, looking to get the same. They fit 944/951, however im not sure how closely the impedence matches the 951. I took the pic from spencers post (hope you dont mind).
Old 12-22-2010, 10:59 PM
V2Rocket
Rainman
V2Rocket's Avatar
lol
impedance on these is 2.4-2.8 ohms, they are a direct plug in for a 944 NA but you would need to tell the DME the injectors are bigger otherwise you will be running an extra 50% rich constantly (stock NA injectors are 24#, these are 36#).
you could use these on a 951 if you put some resistors in the injector driver wires, 951 uses ~5.5 ohm circuits. although why youd do that (same flow as 951 injectors) idk but in a pinch theyd work.
these would be good for someone doing a turbo-my-NA or a supercharger project and will support just about anything anyone would do while keeping the sc a bolt on affair and running pump gas (~275hp)
Quick Reply: FS: Ford brown top injectors, 36#
