What's this for? (PET pic)
Old 04-29-2002, 12:15 AM
951Tom
951Tom's Avatar
Post What's this for? (PET pic)
Does anyone know what part #21 in the pic is for? It's called a Restrictor. Thanks
Old 04-29-2002, 01:59 AM
instigator
instigator's Avatar
Post
it limits the amount of air that is introduced into the venturi tube, i guess its a set amount that porsche came up with and the ventury boosts the vac for the brake booster
Old 04-29-2002, 04:04 AM
Lemon Yellow 87 n/a
Lemon Yellow 87 n/a's Avatar
Post
YO!!
Old 04-29-2002, 09:35 AM
951Tom
951Tom's Avatar
Post
Is it worth pulling the intake manifold to put one on? I noticed I don't have one of these on my car.
Old 04-29-2002, 12:09 PM
instigator
instigator's Avatar
Post
you dont have the restrictor or the venturi ? if your brakes work like you want i would just leave it out
Old 04-29-2002, 01:32 PM
951Tom
951Tom's Avatar
Post
I have the venturi, but no restrictor. I'm wondering if it's causing my idle problem. It'll only idle at 900rpm with the idle screw turned all the way in. It looks like extra air could bypass the throttle, but I'm not sure how this venturi things works inside.
Old 04-29-2002, 02:38 PM
dermass
dermass's Avatar
Post
whered you get that diagram??? i need a similar/highly detailed diagram of the water pump/cooling system. thanks.
Old 04-29-2002, 03:56 PM
nwehtje944
nwehtje944's Avatar
Post
that pic is from the pet cd, Porsche parts Catalog. its very nice to have, I can burn a copy for you if you want, just email me.
Old 04-29-2002, 05:13 PM
edd1em
edd1em's Avatar
Post
Please please please burn me a copy. I would email u but I do not have ur email address. Ill send u a blank cd and some stamps. Mine is edd1em@hotmail.com
Old 04-29-2002, 05:20 PM
Dave H.
Dave H.'s Avatar
Location: Seattle - it's not Hell, but you can see it from here!
Post
click the "envelope with the little man next to it" icon...
Old 04-29-2002, 05:34 PM
bs
bs's Avatar
Post
hmmm... a venturi tube in the brake booster system... interesting. I understand the venturi effect but i always thought that it was manifold vacuum that assisted the braking effort, not vacuum generated from some moving air.
could some patient person explain to me how/why this works?
is this system the reason why my engine will rev up if i brake really hard with the clutch disengaged and the throttle closed?
Old 04-29-2002, 05:47 PM
instigator
instigator's Avatar
Post
BS its kindda a dual effect the vac in the manifold is pulling at the booster but the venturidoes do some as well
Tom that might be a good thing to look at because it is metered it might be getting too much air and playing havoc with you idleing
Old 04-29-2002, 09:42 PM
nwehtje944
nwehtje944's Avatar
Post
edd1em,
wegie944@hotmail.com is mine,
like david said [quote]click the "envelope with the little man next to it" icon... <hr></blockquote>
I also have the factory maunals on CD.
Old 04-29-2002, 10:03 PM
mmmbeer
mmmbeer's Avatar
Post
Dermass, here is a snap shot of the water cooling diagram from the PET. Enjoy! <a href="http://www.diateam.no/porsche/other/water.jpg" target="_blank">water cooling</a>
Eirik Kvello-Aune
<a href="http://www.diateam.no/porsche" target="_blank">www.diateam.no/porsche</a>
Old 04-29-2002, 10:17 PM
tt9714
tt9714's Avatar
Post
I just want to clarify that the restrictor (#21) is a small metal cylinder with a hole through the middle. This part actually fits ~inside~ hose #10. It is held in place with two hose clamps (parts #22 & #23).
Net, the restrictor is NOT visible from the outside of a properly assembled vacuum system. You should be able to feel it through hose #10, but most likely that hose is hard from repeated high temperature exposure.
Quick Reply: What's this for? (PET pic)
