Speed and reference sensors. Which is which?
which one is which the closet to the rear of the car is? And the one closet to front is the ? Now I'm thinking about putting new ones in just because i have access to it right now any tricks to replacing them or is it just one screw remove and replace do they only fit in one way. Just hate to see something fall into a place that causes a even bigger job.
Rear is speed. Looks at the teeth on the starter ring.
Front is reference. Looks at a "pin" on the fly wheel. The pin is actually a set screw.
You set the rear sensor to 0.8 mm to the starter teeth and the other sensor just follows along.
