Timing/Water Pump parts list
So in the not too distant future i'll be doing the timing belt water pump and all that goodness, other than the tools I need I think I have a complete parts list. can anyone tell me from this list if I need anything else or if I dont need any of these
~Thanks
Porsche 924s 944 Belt & Roller Kit - Updated
Porsche Front Engine Seal Kit 944, 944 Turbo
Porsche Thermostat 944
Porsche Thermostat Retaining Ring 944
Porsche Thermostat Spacer
Porsche Thermostat O Ring 944
Porsche Thermostat Base Seal 944
Porsche Water Pump Gasket
Porsche Oil Cooler Seal Kit 924s, 944 & 968
Porsche Water Pump Updated Style 944
Porsche Timing Belt Guide Bar
~Thanks
~Thanks
~Thanks
New oil filter, new hoses, hylomar or your favorite excellent gasket sealer/maker (all can be found in search) a hell of a lot of patience, a lift if necessary, watch VAN's video's on replacement procedure, new bolts and studs for the pump in case you break something, plenty of time and patience (did I mention that yet?) inch lb torque wrench, air filter, pb blaster, a strong back if you do not have a lift available. Install the T-Stat before you install the pump, it will save you grief.
Just off the top of my head.
Some specialty tools that you'll need:
Flywheel lock
27mm offset wrench for tensioner/roller adjustment
belt tension tool
seal puller and driver
and should have a spare rotor if your old one cracks when removing from cam gear
Flywheel lock
belt tension tool
Proprietoristicly Refined
Putyoursoxon,
I saw your first picture with the car on the flatbed. Did you get a transaxle or did one come with the purchase?
In addition to all the above----since you mentioned the FOES (front of engine seals),,, you should have the oil pump sleeve, front crank seal and "O" ring.
Keep all bolts, washers, pulleys, seals, sleeve in the exact order!
If you are installing the upgraded WP (water pump) does your rear black fan belt cover need to be cut out??
This is huge first project and so much can go wrong at any point.
Read all of Clarks manual www.Clarks-Garage.com
AND then take a look at the projects on Arnnworx www.arnnworx.com
GL
John
GL
John
Putyoursoxon,
GL
John
GL
John
