fixed my sloppy shifter
ok I have fixed the following, new shift ****, new shift boot, new shifter below the **** (with a billet adjustable) and tightened up the lower bolt in this picture (was not even finger tight), but it was still sloppy, so I took it by my mechanics today and they found the front bolt was broken and lose so we drilled and tapped it and re bolted it, wow what a great feeling to go to put it into 1st and not slapping the side, rubbing and smoother shifting, there is very little play while in gear now, feels like a new car
Your tranny is WAY too clean.
Regards,
doug
Waterloo, Ontario Canada, eh
86 951 (http://www.pcaucr.org/index.php/visu...egory&catid=61)
01 E320 (W210) 4-matic Wagon (http://www.benzworld.org/forums/w210...body-do-2.html)
00 540i-6 (http://forums.bimmerforums.com/forum...hp?albumid=976)
94 855 turbo Wagon (sold in 09)
85 535i-5 (sold in 07)
76 300D (sold in 92)
83 944 (sold in 86)
I apparently only buy cars designated by number
Regards,
doug
83 944 (sold in 86)
I replaced just the shift lever and now 1 year later its just as bad as it was before. Im going to have to put a bushing in it or replace the rod to fix it for good.
I inadvertently deleted my only photo of it before i installed it. I'm making a second one to give to drifta944 for letting me borrow the spare shifter used, will get pictures of it.
I noticed in the picture that a short shift kit is installed. Many of those kits have a keyed fitment at the rear of the main shaft... when this wears, it will cause the sloppy shifting.
See the pictures...
See the pictures...
