Converting DME to ROW
Old 10-02-2010, 04:29 PM
kombatrok
kombatrok's Avatar
Default Converting DME to ROW
I have been reading the threads that I could find about running the car in ROW mode and not using the 02 sensor and it seems like this could gain a little power at the possible expense of a little fuel economy. However I haven't been able to find a post showing how to actually set the car up to run this way?
Anyone who has done this care to share how? I would like to try it and see what sort of effect it has on my car.
Old 10-02-2010, 04:41 PM
JohnKoaWood
JohnKoaWood's Avatar
There is a pigtail on the DME harness, referred to as the coding plug...
they are #27, 28, and 30 on the linked diagram...
http://dcauto.gotdns.com/illustration/index/203490748
and here is the description of their function...
http://www.motronic.ws/4in1.htm
Old 10-02-2010, 05:03 PM
kombatrok
kombatrok's Avatar
So to run ROW you need to install a 1.8k resistor in the coding plug?
It seems like what it is saying is that US cars have no plug in them, so I would have to make a plug with the resistor in it?
Old 10-02-2010, 05:33 PM
JohnKoaWood
or find someone parting out a ROW car, or that has installed a stand alone EMS in a ROW car... or just install a 1.8K resistor in the coding plug housing and be done with it!
Old 10-02-2010, 05:48 PM
Rogue_Ant
Small Business Partner
Rogue_Ant's Avatar
The ROW maps aren't much different - no real gain by changing to them...
Old 10-03-2010, 01:28 PM
951Saga
951Saga's Avatar
Guess it could be used to confirm a faulty O2 sensor.
Quick Reply: Converting DME to ROW
