Aligning Momo steering wheel
I'm having trouble aligning my momo steering wheel. I attached the wheel to the hub first then put it on the car, but for some reason I can't get it to be centered when the tires are straight, its always off a little to the right or the left.
Any suggestions?
Any suggestions?
I just put one on my car a couple weeks ago. It went on perfectly straight.
Make sure your old wheel is straight before you take it off, then make sure you install the new hub with the "top" at the top. The rubber boot is marked top, and so is the hub itself. Make sure you use the "top" stamped into the hub as top, and not the rubber boot top.
The boot on my hub was twisted around on the opposite side of the hub "top"... I almost installed mine upside down before I saw what was "up"
You'll have to play around with the tie rod ends for adjustments finer than what you can get by moving the steering wheel a tooth. You can do it yourself or an alignment shop will make short work of it...
