Griffin Radiator Install
I have a Griffin radiator that came out of a 951 I purchased.
I am trying to install it in a late 944 and the radiator is about 1.5" taller.
Anyone run into this? I know I can modify the bottom bracket somehow, but I thought I would ask if there is an easier way first.
TIA
TIA
Turbo lower raidator bracket did the trick. It is offset about an incho to accomodate the larger radiator.
The NA fans do not fit either since the radiator is longer....
I had the same problem putting a 951 radiator in my 944S. I just cut the lower radiator support on both sides and welded in a 1.5" spacer.
