front balance seal wisdom
about to rip in and replace my front balance shaft seals on my 87 924S - auto tensioner
looking for any wisdom
also happy to remove and reinstall timing belt, had one almost die from a bolt that backed out and put this one on, but its been whiny for probably 300 miles. i hear thats normal, but to me sound = friction, so i am into seeing if that sound goes away if i double check to see if anything is touching.
i have the parts i think. water pump is still only 15k old. so i think its just those seals.
if anyone has any tips or wisdom to share, i would be more grateful
thanks!
thanks!
Proprietoristicly Refined
The timing cam belt should not "whine". What you have read is the "balance belt' will "whine" when adjusted too tight. Arnnworx has a sound video in his belt change DIY --projects--near the bottom of page. If you have this sound, the balance belt is too tight. www.arnnworx.com
Since you did not mention what tension guage you use, I will guess you use the 924S auto tensioner.
I hope you have another method to test the tension, the auto tensioner is sloppy at best.
Read also the arnworx information on front seals. He does not change the cam gear seal if not leaking--way too much work. YOU MUST replace the cam gear bolt. It cannot be retorqued! The new bolt has a triple square head.
When I am satisfied with my cam belt tension, I double check with the "Water Pump Pully Test". This is not your prime tension test, just a backup. Use at your own risk and skill level.
