Late Fan Control
Late Fan Control
I was curious how common is it for this switch to go bad. I am talking about the one that controls fan speed. Mine only does off and speed 4. I remember my dad having this problem a long time ago, but I couldn't remember if people would buy this switch new or used? Any ideas?
It sounds like it's the series resistor, and AFAIK, it's a dealer only item. Are you ready for it - around $230 for a new one.
But try this first - remove the resistor from the blower assembly and soak it overnight in white vinegar. There are a couple of contacts that get corrosion on them and the vinegar cleans it off. I had the same issue as you and soaking it fixed it.
Here is the new and old part... Its a Porsche part and I never paid anything near $230. It might have been equivilent to around $30. I will have to check the invoice for the price. (Ballast Resistor 944 616 105 00)
That's better - $73.25. But the part number I have is 944-616-101-00-M100. Mine is white and has more pins. I think the one you posted would have worked for the OP though - I just looked up what my car (951) took.
