Stuck pressure relief valve
I'm trying to replace my oil cooler seals but I can't seem to get the pressure relief valve off. I'm afraid of stripping edges to it.
Any suggestions? I don't have an impact wrench.
Thank you,
David
Thank you,
David
Just try penetrating oil. Then get a wrench that fits snuggly and tap the wrench with a hammer to loosen. If that fails get a pipe to put over the wrench and a really big hammer.
Good luck
Good luck
Worst scenario, pull the housing off evenly with the valve still in the housing, it's threaded to the housing, but only an o ring holds it to the block.
You didn't state which model you have...?
They are different for the NA and Turbo..
