If you have the original paper gaskets, they will be junk. Lindsey Racing sells some nice steel rubber coated ones. My old gasket was baked on and took forever to scrape off. Not sure what is involved with the turbo one, but the N/A intake was fairly easy to remove. If your oil/air separator has leaky seals. It would be a good time to replace them since you can access it better with the intake off.
