WTB header
what kind? Do you want aftermarket or need stock? I saw a post on one of the boards for a set of headers. I think they were the 3" that Lindsey Racing sells. They were either on this site, pelican, or 944online. I have a stock 2-3 pipe in the later pipe style if you are looking for an upgraded stock one. The 1-4 pipe I have is broken though. Ended up getting a Bursch header for $315 from automotion.com Well made and fit perfect. Also came with a cat delete pipe.
I have not seen the Lindsey units. The late tube hearer, is a steel tube header, where the early ones are cast iron units. I have always understood that the late headers do flow a lot better than the cast units, the reason for Porsche going to them in 85.5
Be aware that the headers that Lindsey sells are not a direct fit. You have to cut and weld an adapter cone thing onto the existing pipe. Here is a link to the pic with the cone piece that you have to weld on. http://www.lindseyracing.com/LR/Pors...DS-HO944P.html
Hope this helps.
Hope this helps.
