Thoughts on aftermarket fans.
#31
Moral of all my typing in this thread is do it right once, CHEAP makes you do it at least twice and the second time you kick yourself in the *** wondering why you didnt do it right the first time.
#35
Rainman
wiring question:
new fan takes a StrekStrekStrekStrekton of current to start up and then settles to 30-35amps while running high speed. other guys (SC'd mustangs, musclecars, etc) that use the fan (taurus 3.8L) suggest using a 75a relay to control the fan, or 2 40a relays in parallel.
the factory fan relay is a 40a...think i'd be able to just wire in a 75a relay to that socket, or use the socket and split its input and output between two relays and just mount them down there?
#36
Check the wire size to that socket first; not like you need wire sized for a continuous 75A, but it needs to not melt... You may be better off wiring outside the fusebox.
#37
Rainman
i was thinking that too...running a fat fused power line off the battery to the relay, with a signal line from both the AC switch and the rad switch, and then to the fan motor. i could ground the motor to the chassis right there.
question though, the early rad switch only has 2 prongs, does it have a dual temperature setting (one temp sets low speed fans on, higher temp makes high speed) or is it just an on off thing?
Z3M&968 (03-06-2020)
#40
It's still sitting in my garage
There's only been 1 fan installed (driver side) for a year and a half after the other one seized out of nowhere. That single 6-blade stock fan is doing fine even in Houston city driving during the summer - temps never above the halfway mark and verified with my tuning software - but it's probably toward the end of its life.
![Embarrassment](https://rennlist.com/forums/images/smilies/redface.gif)
#41
Friends, Rennlisters, Countrymen,
I live in quite a warm area and as such have a desire to keep my car running as cool as possible. After installing the low-temp fan switch, the low-temp thermostat, an external oil cooler the size of the moon and a low-temp oil thermostat, the next thing to look for is maximum airflow.
In some searches I have not come across any definitive answers of CFM flow for the stock 6-blade fans. They work well, yes, but if an aftermarket fan or fans can flow more air it should be better.
An example of what is available is here, http://cgi.ebay.com/ebaymotors/ws/eB...d=260635519247
Thoughts?
Thoughts?
http://www.banggood.com/Universal-12...l?rmmds=search
#43
