Sunroof help!
Sunroof help!
So my sunroof hasn't worked for years(85.5 NA, no gear sunroof setup), and I installed the microswitch between the sunvisors under that triangle tab, and it worked! For all of 3 days. Now it doesn't work again at all. Before if I would jumper the motor to the open or locked position it would run to the released position, and stop, that's how I knew it was the microswitch. Now it won't run at all unless I jumper it. The directional relays back at the motor are good, I switched them with the blower motor relay and the blower works good with either of them in there. I think it is either the sunroof main relay, or those two red switches on the back of the sunroof motor rail. Is there any way to test these? Clarks garage has me confused on testing those two things so any help would be appreciated! Thanks!
