blinkers flashing fast
Old 07-15-2010 | 12:48 AM
rgs944's Avatar
rgs944
Default blinkers flashing fast
All four blinkers blink fast. I know that usually this is caused by a bad bulb but is that true if it is the same on both sides. I am thinking it may be the flasher itself. If it is the flasher does anyone know if a 86 944 and 83 use the same flasher?
Old 07-15-2010 | 01:16 AM
Grandpa#3's Avatar
Grandpa#3
From: Hawkinsville / Perry, Georgia, RETIRED USAF GO BLUE
Hi, Check to see if the 83 has a relay with P/N 191.953.227A as that is the relay on the 86for a Turn Signal Flasher.
Cheers,
Larry
Old 07-15-2010 | 12:14 PM
rgs944's Avatar
rgs944
fixed. both relays are the same and that was the problem.
Quick Reply: blinkers flashing fast
