Adding fuel pressure
Hi,
Since I installed a new air flow system, and a bursch exhaust system. I saw it fit to install an adjustable fuel pressure regulator from HR. Has anyone had experience with these regulators. Would it also be to my advantage to install larger injectors (maybe turbo injectors??)
Christian
Christian
To accurately answer that question, you'd have to get the car to a dyno that'll measure your air/fuel ratio and the fuel injector duty cycle whilst the car is under load. It's doubtfull that you need higher flow injectors, but why not ask HR what they think. Your parts come with support.
Skip
Skip
