R32 swap?
Why put all this time, effort and money into a swap that makes less than a stock 951 motor makes? If you're then going to spend even more on a turbo setup for the VR6, that makes even less sense.
If you need to be "that guy" who does everything differently, go with the 1.8T, 2.0T or the older 2.2 5 cylinder audi motor.
Personally I'd just do an LS1/LS3 and call it a day.
Audi/VW 1.8T is definitely worth looking at
if it were me, I would look into the 2.0T's though
would be sick to see a 2.7T V6 from B5 S4 or C5 A6 in a 944 though
still, you can't beat performance/reliability of a LS1/x
And yes, a 250 HP VW 1.8 or 2.0 would result in similar performance to a 944 Turbo. I don't have a 944 Turbo, so that would be a good thing. And it's not a 25 year old turbo.
Yes, the LS swap isn't a connect two wires and you're done, but the path has already been forged. There's an instruction manual and all the necessary parts to do the swap are commercially available.
Not so with the VR6 or 1.8/2.0T's. Guarantee you'll spend more money swapping either of those into the car vs an LS1.
Also, you'd rather dump copious amounts of cash into a NA 944 vs selling it and buying a 951? You think it'll be more reliable with a custom engine swap than what the factory did, even if it's 25 years old?
Any VR6 is unreliable. I was dead set on doing a vr6 swap at around the same time vonov was starting his, and after helping my brother work on his two VWs (both vr6) countless times, I decided I hate that motor and I don't want one ever.
The bottom ends are stout as can be. Overall a bitch to work on. Lots of engineering below the level of Porsche. IMO the advantage of a vr6 block over a 944 block comes at power levels which 99% of people do not actually want to get (i.e. pay for).
How about a 1.8t? Simple little engine, iron block, good for huge power.
My VR6 is at 240k km, but is quite clacky. Probably a valve knowing my luck.
I would love to see someone try this. I know it's not a 350HP screamer, but it's a chance to bump RELIABLE horsepower up to 250 with a modern, 16V, German powerplant that (logically) should allow accessories to play nice with each other. I wonder how its weight compares to the 2.5 n/a.
My vote would be A) buy 951. B) LS1 swap (or A+B) C) Swap in a TDI, then at least you would have something totally different. 50mpg, and plenty of power when modified.
You know, I'd be upset if it wasn't true. ![Frown](https://rennlist.com/forums/images/smilies/frown.gif)
Car is apart again, turbo blew. It's back at Vitesse getting rebuilt. Just talked to him in fact, bearings, seals, and turbine wheel/shaft are getting replaced.
v8s are not easy to swap in. The 944 is not made for a v8. There are lots of sacrifices and/or compromises you would have to make.
A 1.8t seems puny and not worthwhile, but consider this. Everyone would just do a 951 swap if it was more reliable and less finicky. The 1.8t is just another 4-cyl turbo, but no balance shafts (leaks, belt issues, vibrations), no alusil, no oil pickup tube cracks, no freestanding cylinders that move, no cracked ceramic port liners, no melting AOS, cheaper and more diverse aftermarket.... etc.
In the end, a v8 is more reliable at 500hp. But the 1.8t can still dish it out better than a 951 motor, and it requires less molestation to the car than a v8.
I have never had an audi 5cyl, but I would love to. My audi 90 has a v6 and I wish it was a 5cyl.
1 Post
I did a particularly rare/undocumented swap, with no known sources for documentation/help. It took months of planning, sourcing parts, hand fabricating parts, lots of measuring and remeasuring. I'm not talking about a hack job back yard swap, I mean a swap that will be reliable, "easy" to work on, and fully superior to the original engine/driveline.
After all that hard work, the swap is functional, looks good (not show quality, but at least a factory type purposeful quality look) I easliy make 3 times the stock power, but what it cost in time/labour/parts, I could have had a 700+hp 6spd v8 with enough money left over to have fun upgrading other parts of the car.
The main reason behind engine/driveline swaps is either to "be different" or to put in a more reliable/available/easier to work on/tech support/aftermarket upgrade support. (or any combination there of) That is where companies like "Jags that Run" came from. They swapped readily available powerplants with huge aftermarket support, into exotic/foreign cars that had comparitively rare engines.
My VG30ET swap (late model 300zxt) into a First gen 280Z I know I know this is a Porsche forum, but this is where my experience originates.
![](http://i9.photobucket.com/albums/a54/ZR8ED/DSC01667.jpg)
... The 1.8t is just another 4-cyl turbo, but no balance shafts (leaks, belt issues, vibrations), no alusil, no oil pickup tube cracks, no freestanding cylinders that move, no cracked ceramic port liners, no melting AOS, cheaper and more diverse aftermarket.... etc.
ZR8ED, you just proved my point about putting an LS1 vs a VR6 in. Don't spend tons of cash, effort and time to put in a motor that's
#1 Unreliable
#2 Doesn't make very much power
#3 Doesn't have a large, cheap source of aftermarket parts
The LS1 is reliable, makes tons of power and has a large source of cheap parts. The VR6 doesn't. The 1.8T is a great motor, but again, lots of time will have to go into making it work in our cars.
#1 Unreliable
There is bound to be a good reason for this, but I have never heard anyone talk about putting a 928 V8 in a 944, seems to me that it would be a good choice, but I'm far from being a mechanic.
