big reds on n/a
I personally think Big Reds will be overkill on your car. 928S4 brakes are more than enough braking power for your car and will fit under 16" 951 fuchs with a 1/4" spacer.
S4's on my car:
<img src="http://boards.rennlist.com/upload/tifosiman_image41ab.jpg" alt=" - " />
Tifo
S4's on my car:
Tifo
I agree with the reds being to big but ive heard that it difficult to fit bigger brakes on a early 944, dunno where, but i got some 911 c2 -92 model front calipers available for cheap atm, and i wonder are these the same as the s4 brakes? or similar in some way? do i need adapters for them?
Thanx
Thanx
I have a set of twin piston claipers from a 944 turbo, that I want to fit on my 924S. Do these require an adapter and spacer, or do I just need to mount the 944 Turbo hubs? Thanks
Louie
Louie
</font><blockquote><font size="1" face="Verdana,Tahoma,Helvetica">quote:</font><hr /><font size="2" face="Verdana,Tahoma,Helvetica">Originally posted by Lousailor:
<strong>I have a set of twin piston claipers from a 944 turbo, that I want to fit on my 924S. Do these require an adapter and spacer, or do I just need to mount the 944 Turbo hubs? Thanks
Louie</strong></font><hr /></blockquote><font size="2" face="Verdana,Tahoma,Helvetica">944 turbos/S2 brakes are FOUR piston calipers...
</font><blockquote><font size="1" face="Verdana,Tahoma,Helvetica">quote:</font><hr /><font size="2" face="Verdana,Tahoma,Helvetica">Originally posted by dave120:
<strong> </font><blockquote><font size="1" face="Verdana,Tahoma,Helvetica">quote:</font><hr /><font size="2" face="Verdana,Tahoma,Helvetica">Originally posted by Lousailor:
Louie</strong></font><hr /></blockquote><font size="2" face="Verdana,Tahoma,Helvetica">944 turbos/S2 brakes are FOUR piston calipers...</strong></font><hr /></blockquote><font size="2" face="Verdana,Tahoma,Helvetica">I'm guessing he meant 2 pistions/side, i.e. 4 total (really 8 when you consider left & right combined). Kinda like people refer to the 16v head as a 4v head.
Louie</strong></font><hr /></blockquote><font size="2" face="Verdana,Tahoma,Helvetica">944 turbos/S2 brakes are FOUR piston calipers...</strong></font><hr /></blockquote><font size="2" face="Verdana,Tahoma,Helvetica">Yup. And with good pads they provide awesome braking on my 951. Definitely enough for a 951 and more than enough for an n/a 944 or 924.
The big reds are overkill on a 944. Buy 951 brakes and put the money you save into engine upgrades so you can make use of those brakes.
I think you need to get turbo spindles to run them. I know that the turbo calipers don't fit the N/A cars. I'd like to find adaptors though, I have a cheap line on some turbo brakes.
To mount the 951 calipers, you'll need a lot of stuff, all from an early offset 951 (read:1986 model):
2 Spindles/hubs
2 Struts
4 mounting bolts for the calipers
2 rotors
optional:
SS brake lines
Blue fluid
951 brake bias valve
To mount S4 calipers, use the same list above, but:
substitute custom rotors for the 951 rotors
Add 2 adapters (Powerhaus, Koklen, etc) to fit the S4 calipers to the 951 spindle.
All of the above is pertaining to an 86 or older car. Late offset cars are different.
Tifo
2 Spindles/hubs
2 Struts
2 rotors
optional:
SS brake lines
Blue fluid
Tifo
