What can be done to the front of the engine with it in the car?
Plan on doing my timing belt, balance shaft belt, and water pump. Was thinking about doing the seals. How much is doable with the engine in the car?
Finishing up belts/wp change on mine. Checked my seals, but it looks like they were done not that long ago. Belts and wp didn't need to be done, once I had the covers off...but had the parts and figured I might as well do it now, so I knew the mileage they were replaced at. Also replaced the cam tower gasket, vac lines and other odds and ends. All with the motor in place. Definitely get a deep 24mm socket for the crankshaft pulley bolt. I took mine out with an extension and std 24mm socket and it was a pain with the fans and radiator in place. With the deep 24mm, it is a little shorter than that combination and much easier to do the job with rad and fans in place. Good luck on doing the job. I definitely would recommend getting Arnnworks tools...the timing belt tension tool is great! Easy to use too!
