1st post...with a request
Hi all, I am new to the Porsche world and have an 84 944 that has an old aftermarket alarm (non-working). I am trying to remove all the associated alarm wiring from the car but am unsure about the spliced-in coil wires.
My request is for a clear pic of someones factory original coil installation so I don't cut the wrong wires and really cause some problems.
Thanks in advance.
Thanks in advance.
From: Hawkinsville / Perry, Georgia, RETIRED USAF GO BLUE
Hello cew, A Big WELCOME to the Forum. I don't have an answer to your question, but maybe someone else will chime in and give you one. A non-factory alarm system is anyones guess. Clean off all dirt from the coil wires so you can see the color of the wires. I looked in the WSM for the coil and it shows a Black wire and a Solid Green wire. The factory Alarm also has a Solid Green wire that connects to the Green wire going from the coil down line someplace. I hope this helps.
Cheers,
Larry
Cheers,
Larry
I would like a pic of the coil itself and the wires that attach to it.
Here is what I have now. The green wire (butt-spliced to a blue wire) goes to one post on the coil and the black wire (also spliced to a blue wire) goes to the alarm control box? or ignition switch? then another blue wire goes back to the other post on the coil.
I would like to remove all traces of this old alarm and return the wiring back to original.
Thx.
Thx.
