Drivers side power window regulator replacement
My power window goes down fine, and goes about half way up fine. Then it just sort of goes nowhere or moves slightly up and down no more than a 1/8". If I pull up on the window while pushing the button, the window goes up but will still fall back down until it reaches nearly alll the way up. Is this the regulator gear teeth bad?
Scott Harris
1984 944na
Scott Harris
1984 944na
Any tips for replacement? I've replaced domestic regulators before, but never a Porsche. I probably need tome $750 special tool that has been stored in Germany and must be flown in on the Concord.
Scott Harris
1984 944na
1973 911T targa 2.4L MFI
Scott Harris
1984 944na
Not really. Helps to have an extra pair of hands around on reinstall, or a big roll of duct tape.
When you get the thing loose you won't believe it can fit out through the rear hole punched in the inner sheet metal, but it will.
