Odometer gear
Hi,
I bought an odometer gear from Scott Levy, Looks good, but I have one problem, his instructions start with the instrument panel out of the car and on a table. How do I get the instrument panel out of the car to start with????
Christian
Christian
You can use the applicable parts of our dash removal procedure: <a href="http://www.tech-session.com/Paragon/Tech/late_944_dash_replacement.htm" target="_blank">944 dash replacement</a>
I have a specific one going up soon, but that won't help a bit right now, will it
Good Luck!
Good Luck!
Here is a dash removal instruction that I wrote to replace burnt dash bulbs (Late model dash - I think this is 86 and later) It is a bit easier than Paragon's instructions (No offense!)
<a href="http://forums.rennlist.com/scripts/rennforums/ultimatebb.cgi?ubb=get_topic&f=15&t=000157" target="_blank">Dash Removal</a>
Good luck - be gentle - that old plastic is brittle!
Thanks guys, Worked like a charm, I had to tear apart the dash and replace it twice due to the tricky gears, but I eventually got it to work without breaking anything....Amazing...me not breaking anything for once.
Christian
Christian
Former Sponsor
[quote]Originally posted by Irish:
<strong>Who is Scott Levy? and how can I contact him to get an Odometer gear? as mine is also broken.</strong><hr></blockquote>
Here I am........
Check the web site's below.....
Here I am........
