HELP: No tail lights or marker lights on left side.
I almost got this car put back together when I discovered I had no tail lights or marker lights. I changed bulbs and checked fuses (one was blown) and got all tge lights on the left side working. Nothing on the right. Head lights and fog lights work fine and blinkers work all the way around. No tail or markers on left side. Looks like it is being fed through a black/gray wire but it has no voltage. But there is voltage at the headlight switch (black/gray) I have cleaned and tightened all the grounds and searched through the archives to no avail.
Problem solved
I found of piece of wire spliced into the headlight switch and left hanging. Dont know what it was for but I took it out and replaced number 40 fuse which was blown. It was for the right side relay gong. (whatever that is) I also cleaned the grounds near the driver side headlight and it the rear hatch area.
