Lowering and Torsion Bar Replacement.
I am upgrading my 86 na stock torsion bars with 28 mm torsion bars. I want to lower it, as the bar is stiffer how many turns should I do? If one turn on a set of bars that have NOT been replaced with stiffer bars is good for 2 1/2 inches, how much less would my stiffer bar lower the car with the same rotation?
Search "torsion bar index" here too.
I looked at Joe P's sheet, perhaps it is not complete, or the more probable explanation would be that I am not smart or patient enough to fully understand it.
I guess I should try one spline, and see how low it goes? I do not want to do it twice. Which will probably be what I do.
well...what don't u get?
joe's excel lets u input the before TB, after TB, preferred drop. it then calculates how much angle is needed, how much height at the unloaded suspension should be. inner splines are 9degrees, outer splines are 8.8 degrees. figure out how many inners u need and how many outers u need to get close to the target degrees.
I did not realize that it was a working spread sheet, the version I found was not a working spread sheet.
Here is the link;
http://az.pca.org/archive/tech/artic...barSetting.xls
Here is the link;
Not sure what your stock tbars are, but if they were 23, then going to 28 will raise the car by about 97mm. An inner spline click will drop by 67mm, an outer by 60mm. So do 2 x outer and the total drop is about +97-2x60 = 23mm.
Also, if you don't already know, but going from 23mm to 28mm is a much larger change than it would appear. I don't have the actual rates to hand but it's amazing what just 1mm makes let alone 5. Unless you are changing other stuff this should entice a lot more tendency to oversteer.
I have kids...etc. That job took far too long. My 0.001 cent opinion on the matter is that with the time it took away from the family, perhaps the coil over solution would have been a more reasonable route. Just a thought.
