CHEAPPP S2 CAB!!!
1 Post
Well the top would not be very cheap. Couple grand I figure. A lot less if you have some reasonable connections. I can certainly comment on how much fun it is cruise around with the top down! It is an attention getter!
Up my way, you can't get one for under $12K, and more common in the $15K range. Now at that price, you get some service history... So I say, buy and it and do your own service. Same money, and you will KNOW the service history. You could easily spend $12K and get a car with 3yr old serviced belts etc.
Well worth it if it halfway passes PPI. Heck if you have a coupe you could probably get away with not fixing the top and only driving in the sun. Tape up the old one in case of a flash rain shower and otherwise leave it down all of the time.
Fun in the sun
Fun in the sun
1 Post
You put the top up? Mine is now top down more than up (garage storage, fair weather car mostly)
It is a good point. Leave the top down. Wouldn't be a DD though. It might get you by until you can get the top repaired/replaced.
