Auxillary electric fan on a stock 951 oil cooler?
Does anyone have advice on installing an electric cooling fan on a stock 951 oil cooler? The dimensions of the stock unit is causing me difficulty in finding a good setup/fan.
I didnt have much luck with my stock cooler on track - dumped it for a Setrab. There are threads about what fittings to use (I think you need an M22 to AN10 adapter) then just mount the cooler and cut/run the lines up to the stock oil filter housing.
