Windshield replacement? Can I use 944 glass in a 968? Need your help!
I called the local glass shop a new windshield for my 968 is $1100 Canadian, but I also had him check for a 944 (S2) and it was $700. Are these interchangeable? Thanks.
could someone maybe take a peek at their glass and see what the model # is?
My glass model # that I read off the windshield says,
Sekurit
Saint Gobain
43R-00115
DOT 32/M91/AS1
VSG tinted
9
Sekurit
Saint Gobain
43R-00115
DOT 32/M91/AS1
VSG tinted
9
I'll look at mine tonight for you if nobody else answers first. The rear quarter glass is different but I would think the windshield glass the same.
I just called another shop and they quoted me $400 installed for a 91 944 windshield! This is waaaaay cheaper than a 968 windshield, I sure hope they are interchangeable! Will save some serious $$$$$
I don't care about radio antennas and the like as I don't listen anyway.......
my '89 944 with airbags (it supposed to be a diff w/s I'm told) says
Sekurit
Saint Gobain
43R-001126
DOT 27/M75/AS1
VSG tinted
this one has an antenna in the glass
Sekurit
Saint Gobain
43R-001126
DOT 27/M75/AS1
VSG tinted
Location: Seattle - it's not Hell, but you can see it from here!
checked PET, they're both 944 part numbers:
clear: 944: 944 541 011 13; 968: 944 541 011 16
tinted: 944: 944 541 011 12; 968: 944 541 011 15
tint band: 944: 944 541 011 14; 968: 944 541 011 17
it might work, but i'd like to see both cars together to eyeball it and maybe take measurements.
good luck...
good luck...
</font><blockquote><font size="1" face="Verdana,Tahoma,Helvetica">quote:</font><hr /><font size="2" face="Verdana,Tahoma,Helvetica">Originally posted by David R. Hendrickson:
<strong>checked PET, they're both 944 part numbers:
good luck...</strong></font><hr /></blockquote><font size="2" face="Verdana,Tahoma,Helvetica">I have a receipt from the previous owner who replaced the windshield glass in 99 the part# is 944-541-011-14 which according to your PET info is a 944 glass.....so it must be the same!
I wonder what the difference is between "tinted" and "tint band" ??
Thanks for the info!
I just looked for all my receipts, as my PO replaced the windshield in my '89 S2. It must be at my mothers place, but if I recall correctly, it was much lower then what I expected, somewhere around $300 or $350? I'll be able to get to the receipts on Friday to give you the part number and price if that would help.
-Ethan
-Ethan
peckster...my early '85 has the same number as your late series '86 (43R-000-880) so I guess the early & late are they the same size. do you have an antenna in the glass? I don't.
while we are at it, is the 924 w/s the same size as the 944?
air conditioned cars used to come with little darker/full tint windows...while the tint band was clear except for the top 4-6 inches. dunno if this is still true.
