AC Noise
When the air is on,there is a sound similiar to a small door opening and shuting. What the heck is it and is it a problem as long as I don't mind hearing it? AC works gr8. Thx! Dman
![Cool](https://rennlist.com/forums/images/smilies/cool.gif)
Should be the blend control flap. It changes positon dependant temperature you want. When you first turn it on, it goes to full cold, blocking warm outside air. After that, it "blends" warmer air in with the chilled AC air.
You can lube up the mechanisms and it might not be as noisy.
