Welding in a O2 Sensor
Well my car failed emission and I am 90% sure it is the O2 sensor. So I go underneath the car to replace it and to my surprise some dumb *** welded in the sensor, now I’m sure that’s not right. To make it worse the sensor that is in there now doesn’t look factor. So what am I to do, grind the thing out?
You can add another bung, I did and put in a wideband sensor to monitor A/F ratio.
Just determine which would be the least painful, both ways will most likly require some exhaust removal.
The extra bung can be bought at most Hi Performance shops.
Good Luck
Good Luck
