Turbo Radiator in an NA
You can gain some height by using the turbo lower support, but at 1.5"+, a shim (block) may need to be fabbed & installed w/ longer bolts. Give me a sec, and I'll measure the actual mounting differences...
Greg
EDIT: 1986T has a vertical mounting space of 15" / 1987 N/A is 14". The turbo lower support is stamped with a recessed area of 1", so if you use the turbo lower support, the T rad should fit in the N/A. At the most, a small spacer and 4 longer bolts, and adjust the top mounting bolts. BTW, dcAuto has the turbo support cheap...
Greg
