Lindsey Racing AC delete install questions
i got a lindsey racing ac delete kit second hand and i think i may be missing parts...
this is the new bracket that also can fit the small bosh alternator. my problem is, with the stock alternator, the bracket is thinner than the two tabs on the alternator, what is supposed to keep it from sliding back and forth?
the hole in the stock ac tensioner is also for a larger bolt than the alternator tensioner tab accepts. do i just use the smaller bolt despite the slop?
the electrical wires also seem a little short to make it to the alternator. they make it, but not by much...
Rainman
how much wiggle room is there between the alt tabs and the bracket?
for the tensioner bolt you need to find a sleeve that fits the tensioner hole and the bolt hole, i had one before that i just found somewhere but i sold it with my old delete bracket.
there is a TON of wiggle room. let me go measure
was i supposed to have a sleeve left over that fit here? i had one, but it was too big i think.
let me run out to the garage and get more info
