Its time to play name that part !
1 Post
I got a new part to name.... Or more what its for, I can't find it in the 944 1983 shop manual :/
All I know is that its a relay of some sort and have alot of wires but only 2-4 go into the fuse box area...
And the relay is totaly destroyd, I cant read anything on it and need to find out what its/was for :P
I used this special electricians tape.
Scotch 2242 Linerless Electrical Rubber Tape
I removed the broken down cover and then rapped the wire bundle with this tape.
The trick to this tape is to stretch it as you wrap, once on it stays on and looks good. Worth a try.
If you would rather a new cable this might be it
Pelican Parts
OEM-94461210700 Genuine Porsche Part: BRAKE WEAR HARNESS
- This is a special-order, non-returnable, Porsche part $102.50
Pelican Parts
1 Post
Anyone know how to make a wiring for the backuplight. I had a switch in my center console for it, but wanna use the one on the transmision now. Need some sort of paint photo to show how I hook the wireing up. Im pretty new to wiring a car, got alittle over newbi skills in powerstuff
