seat mount question
#46
The main problem I have with the aftermarket seats, brackets and sliders is head clearance.
I have a tall torso so my head was rubbing off the roof (racecar, no more anything inside). The way the stock mounts are makes it difficult to add any metal tabs on where to mount the rest of the assembly and still get head clearance. Metal tabs (what Joe is thinking of) + sliders + seats does not make it for me.
I could do without sliders, which would solve this problem, but will create a new one: will I be able to climb off the car with the cage, the hans, the helmet and the seat side restraint (I have the HRV seat...).
It's been a real pain for me. So I came up with the idea of a stainless steel tab. I shall have them tomorrow and I will post pictures during the weekend.
Now it seems that I will also have to take care of the stock mounting location...
Joe, can you explain more in details what is you idea of the floor tubong you are thinking of?
c.
c.
#47
not sure how you have headroom issues
my only issue is the seat's width
the top "ears" are touching the door panel (but not pushing against it)
I think I like Joe's idea - I might ask the guy who's going to be welding the floor for me if he can weld a piece of square tubing for me in place of stock 'seat mounts" - and use this tubing as a new seat mount, and do what Joe did - bolt right through the floor with plates underneath
wonder if I'll still be able to use stock seat belt holes for a 6pt?
#48
hm, I was thinking - and here's another problem I might be facing
my sidemounts are right angle L shaped - on both seats
I may have to "mix" them up, and mount both sidemounts like:
1) L *seat* L
or
2) _I *seat* _I
because if they are mounted like this
L *seat* _I
then the distance between the holes is 17"
while stock location for sliders is only 16"
which means I would have to "step" .5" from each side to drill new holes ... which is not THAT much room ... though I am sure it would still be stable
I'd rather have the mounts like in #1 and step 1" from the existing hole, just to be on the safe side
also, another *stupid* moment of mine, I have NOT actually had both seats in the car ... so I don't know if the "wings" of the seat are going to overlap or not ... the 2nd seat might actually not be useful ... but I'll check this out today
Joe, how thick of a plate did you use for underneath the car? It doesn't has to be REALLY thick does it? I was thinking that an old computer case siding might work ... these things are surprisingly sturdy ... and I have somewhat of abundance of these, LOL
1) L *seat* L
or
2) _I *seat* _I
L *seat* _I
#49
but all in all, I have 2-3 options of how I could mount the seats, once my floors are patched, I'll be sure to take pics and make explanations for "future"
#51
The larger and thicker the base plate under the floor the better. I used what had laying around. Just remember there is alot of force in crash and you don't things bending or ripping out.
#53
Thanks Charles!
I would have had to drill out the same hole s you did, lol
you have your adapters running from front to back, I was thinking that it might be "safer" having the bar run across the sliders?
did the holes on your sliders align exactly to the original seat mounts on the car's floor? on mine looks like I'll have to drill a new hole on the slider ... or I bolt through the floor like Joe did
