cant get the M030 19mm rear sway bar in!
i took the old one out and am now trying to put the 19 mm in. and no go, after a lot of pushing....i got both sides on the 2nd hole but NO way am i going to get the bushing clamps on, it seems like the exhaust is in the way and also the rear control arms....the car is on jacks, should it be on ramps?will it make a difference?
what i'm worried about right now is that i think the bar is under pressure in the middle and i think it might be slightly bent because it took sooo much effort to get the bolts in....what should i do?
You should be able to get the bar in with the car up on jack stands (suspension unloaded)....but to install the bar and the rubber bushings unloaded (unstressed), you want the suspension to be loaded (on ramps)..
so give that a shot...
ok i unbolted the rear part of the exhaust, from the cat back....and its hanging a little now and the bar moves freely but the bar the the rear control arms bolt onto is still in the way, i cant get the bushing bracket things on. shoudl i lift the rear control arms with a jack?
No clue as to your interference problem, but when you solve it, you'll likely find that the bolts seem too short for fastening the saddles over the bushings on the two inner (chassis) mounts. Start the upper bolt about two turns with the saddle in place; then use vice-grips to pull the lower end of the saddle in to where you can start the lower bolt thru it.
Jim, once wasted half an hour figuring this out.... <img src="graemlins/c.gif" border="0" alt="[ouch]" /> <img src="graemlins/jumper.gif" border="0" alt="[jumper]" /> <img src="graemlins/c.gif" border="0" alt="[ouch]" />
[quote]Originally posted by Andre:
<strong>ok its official....i'm blaming it on MA school systems....</strong><hr></blockquote>
Sometimes it so hard to be quiet... <img src="graemlins/roflmao.gif" border="0" alt="[hiha]" />
We're not laughing with you, we're laughing at you. <img src="graemlins/xyxwave.gif" border="0" alt="[bigbye]" />
Share this with your other MA buddies - they may need it:
<a href="http://www.tech-session.com/Paragon/Tech/944_rrsway.htm" target="_blank">944 Rear Stabilizer Installation - Tech-Session.com</a>
Skip [went to Mass schools until age 10 - and, I'm oakhay]
and.........since I am about to this next month with the 30mm and the 19mm, I thank you for your trouble, glad you got it in. So now
<img src="graemlins/drink.gif" border="0" alt="[cherrsagai]" />
