I think so. 1.4" is bottoming the piston in the bore (944 MC), which is not normal stroke. Normal piston stroke falls short of that to prevent damage, etc.
cool.
one thing i am concerned about: the 944 master has 3 lines coming out of it, i believe one is for the rears and the fronts each have their own lines. the mazda only has two ports on it...could i T the fronts together or should i keep looking for a 3-port cylinder?
The smaller the diameter of the piston, the higher the pressure in the outgoing line. That's why the later cars have a smaller piston, because they're pushing two pistons/caliper. If the bore and stroke is close, they should be fine. since the double piston Mazda calipers require more juice and pressure, the Mazda might just make your brakes a bit "touchy"..just spitballin..
