Rennbay Shift boot
Indeed...Travis is great ! To the OP....I do hope that you attempted to resolve your concern with him (at Rennbay) prior to jumping on here to call him out.
Anything I've purchased from Rennbay has been great and I've met Travis several times....great guy and a quality businessman.
I love my shift boot from rennbay, the photo on the website does not do much justice. Boot looks much better in person.
I thought it would be low quality leather but it is great! Looks and feels much better than my old beat up fdactory boot. I also got the stainless center cap to spice it up a bit. From what I recall installation was not difficult just took me a while to get the plastic ring to fit perfectly. I was never under the impression that the boot would come with a replacement plastic part as that is a factory item.
So for $50, your expecting a new boot, **** and frame?
LOL
give your local dealer a call and see how much they charge.
LOL
All things aside i have already admitted my mistake, by not reading the fine print. I must say the shift boot is very nice but..it doesn't help me at all, because i am not any closer to having a new shift boot in my car. I still need a plastic ring (because my last one broke) and of course, a shift cap that i have trouble paying 20+ dollars for.
If you were a working college student like me you'd understand my complaint alot better, stop trying to troll me mmkay?
As a fellow broke college student - you should have taken the time to read the description. The shift boot is nicely priced and I've never had a bad experience with Rennbay. Also, why do you even need a new plastic clip-y?
Anyways, i have said multiple times now in my previous posts that my plastic clip..BROKE. Hence my bitterness about paying lots of money for something i already have. Kapeesh?
i bought my car in college too, but i could justify it because i worked 40-60 hours a week on top of being a full time student. i think its great that you are part of the 944 family, but your financial situation is not our problem, and not the problem of the great list of vendors these cars have. many of them are very knowledgeable and willing to take the time to help you.
for most small parts, like the plastic clip you are missing, your best source is going to be second hand from fellow members here. rennlisters have saved me tons of money on small parts here and there. i have had a great experience with all of them and wish i could list them all out but the only one that directly comes to mind is ideola. he always seems to have a parts car and is a pleasure to do business with.
I hope you kept the plastic clip, because unless you've totally trashed it, you can probably repair it with a paper clip (or part of), a lighter (though a small propane burner is better) and pair or two of needle nose pliers. We used to 'fix' broken plastic bits of photocopiers/printers in my days before uni (college to you state side folk). Just heat suitably shaped parts of the wire up and melt them into the plastic to repair it...
Though if you've broken it in more than one place, I suggest that you look for a spare in a breakers yard... if you've busted it taking it off, then you likely forced it too much, which means you were more than likely being a little bit impatient (something I am often guilty of!) and when things don't move easily it's usually for a reason, like a missed screw/nut/clip.
I recently bought the Rennbay shift boot, knowing it was only the boot I was getting, as even from Pelican or someone like that the Porsche replacement was at least 300usd, and with a little bit of leather preserve acting as a 'lube' managed to coax the boot on with only a mild amount of effort. I also bought a stainless steel insert, and though while mildly miffed that it is cast, not milled, have to admit that it looks the bee's... when finally installed...
But whatever you do, don't try and work on fitting the boot insitu, i.e in the car, remove the ****/shaft section off the selector and use the floor to push against, it's much easier. While you're working on the boot, check that the inner boot (silicon like rubber) is also not split, if it is, you'll get a nasty smell of fumes in the car (ask me how I know) that instantly gets worse the moment you open the window...
Also there may be a certain amount of 'play' in both the plastic bearing that the ball joint at the bottom of the selector rod goes into, or the rod that connects the gear shift to the rod going to the gearbox. These bits are worth replacing, as it'll make the world of difference to your gear-shifting, which is most important when dragging off that 'ricer' at the lights !
Sorry, but if you're feeling a bit stressed by the price of a few parts, I'd sell the car before you have the 'joy' of facing a 'Milkshake' which is something I have to deal with right now... !!!
ps. Milkshake = water-in-oil or vv, i.e. often a very expensive repair...!!!
+1000000
ps. never buy a porsche that sat in storage for 6 years
Lol ya, Ive had to have a bit of a reminder about that thanks to you guys, my car has been running so well in the past few months everything ive had to fix are non-mechanical. I shouldn't have forgotten about how much more expensive a brand name Porsche part would be.
Thanks for the advice Koren, i will look into that.
Damn that totally reminds me, just so you guys understand what my current "boot" situation looks like right now, since it is clear by now that i am not using the plastic ring that has been broken, i will post a pic to show how comical my whole center console looks.
Seriously, if you are complaining about a $42.50 shift boot, you are in for a rude awakening the first time you have to actually replace something to keep the car running, like a full belt, roller and waterpump R&R.
Tom
