A/C condenser
![Angry](https://rennlist.com/forums/images/icons/icon8.gif)
i was recently being a moron and i tried to take out my A/C condenser. as i was disconnecting a fitting, one of the hoses snapped right off the condenser. i have been told that its not good to use a used condenser. is this true? if not... has anyone got an old one for a late model 944, cause i do know that the bracket is different.
Budding Photographer
Good luck on finding a used one that doesn't leak. I tried 2 different used ones and both leaks after having them ck'd out. They are in such a bad position up front and as a result they take a lot of beating.
Both used ones that I found where in the $75 ballpark, but again neither worked. I ended up buying a new aftermarket from Ian @ 944online.com for about $220. Ian is a very honest guy to deal with and the part works great. About $100 less than new OEM one to boot!
Hope you get yours figured out and working soon!
Former Sponsor
You may also want to try Griffith's. I have one of his on my car and it's cold enough in there to store meat. He updates so more air gets to the radiator.
<a href="http://www.griffiths.com" target="_blank">Griffith's</a>
