Fuel cut offs since the fuel filter change?
Hi!
Since about a month (exactly since I've changed my fuel filter), fuel cut offs occur on 3rd-4th-5th gears accelerations at full throttle. It doesn't happen in any acceleration cases, but when it happens it becomes even worse when I try it back. It then occurs on about 3/4 throttle accelerations: faster and with less efforts when there's alot of load (in 5th and 4th gear at lower RPMs).
What could cause that? Could my fuel pump be tired? Did the fuel filter change cause higher boost, so boost cut offs?
Thanks ALOT for you help...
